Author Topic: Is there a possibility to create a tube along a spline?  (Read 11563 times)
Maximilianibus
  • Bla Bla Bla, Mr Freeman!
    • Please Subscribe!
« on: November 14, 2010, 06:54:29 am »
hey guys,
im working on a character(my other thread, the mod)
and now i need a not-straight tube.
frankly, im too lazy to do it by hand.... ;D
is there any script or tutorial?
thanks.
greetings
« Last Edit: November 14, 2010, 08:12:28 am by Maximilianibus »
$imon
Re: Is there a possibility to create a tube along a spline?
« Reply #1 on: November 14, 2010, 07:57:53 am »
You can extrude a circular spline along the path you want.
- Draw the path that the tube has to follow
- Make a x-sided N-Gon that has the diameter of your tube
- select the N-Gon, go to Build>Extrude and choose 'path' on the left, set the other settings as you want
- click 'ok' and click on the path you drew at the beginning
that should work ;)
Maximilianibus
    • Please Subscribe!
« Reply #2 on: November 14, 2010, 08:12:08 am »
thanks! ill try...
« Reply #3 on: November 14, 2010, 11:29:03 am »
I find NickE`s  ASL script is a very quick option, I assume that you know where to add the script .
Just rename your spline to tubepath  then click the  icon tubepath, then drag in the work area
It is a Parametric shape initally, so alter the default values
ie: Sides = 12, default(6)
    Diameter = 2, default (6)
    Divisions = 60, default (8 ) or other values that suit your needs. The more divisions the smoother the tube becomes ;D
    Then convert to mesh  then you can safely delete your spline.
    I attach the a8s file,  and screenshot of script in action.
« Last Edit: November 14, 2010, 11:36:39 am by kreator »
« Reply #4 on: November 14, 2010, 03:43:28 pm »
If using the 'Extrude along path' method suggested by $imon, be sure to create both splines (ie the path and the N-Gon) in Front view.  If either spline is created in another view the spline coords get messed up and the N-Gon doesn't correctly follow the path.
