Hey there guys.
 C if this helps to shed some light
Using combs after creating hair.
 1) select the 'phur comb button' and drag out the dial thing. Move it to where you want it, covering some mesh as well as fur. (Scale comb with scale tool if needed, turn comb dial if required.)
 2)double click 'comb' shape to do any editing in the comb parameters, then click ok.
 3)Now,
double click the 'phur'shape,  to bring up the parameters of the 'Phur'.
(Not the comb shape).  In the "phur' parameters, put a '1' in the 'influences' box. Click 'ok' and the comb should now be affecting the phur.
 You can keep going back in to phur and comb parameters after that, and will pobably see that there is already a '1' in the influences box, but thats alright because the changes you make will still come into effect when you push ok again.
  Hope that helps.
