Pages: 1 ... 29 30 [31] 32 33 ... 46
Author Topic: Changed to Older Releases [builds 1162 to 1230]  (Read 1096241 times)
Re: Current Development Release - Build 1194, October 20, 2015
« Reply #450 on: October 25, 2015, 02:15:14 am »
What new look? mines still the same !!  :(
ronaldefarmer
    • Ron's Website
« Reply #451 on: October 25, 2015, 02:48:39 am »
Build 1194 has a cool gray look on my computer, like the picture in my previous post. Isn't that new with 1194?
« Reply #452 on: October 25, 2015, 06:08:29 am »
Is this a windows 10 thing or certain graphics cards dont give the same result?No change of look on mine either.
« Reply #453 on: October 25, 2015, 06:24:02 am »
I don't think Steve's officially announced the new theme yet. You may not see the new changes if you're running Anim8or on a system that already has the registry setting from a previous dev release, or something to that effect. It's not really my place to tell you how to bypass it, though this post hints how to do it yourself :P
« Last Edit: October 25, 2015, 06:25:52 am by Raxx »
« Reply #454 on: October 25, 2015, 07:07:55 am »
 ??? registry.... ;) fear word... :)
thanx for the insight though Raxx
« Last Edit: October 25, 2015, 07:08:40 am by captaindrewi »
« Reply #455 on: October 25, 2015, 09:02:41 am »
Just out of interest some of my scripts do not work with this latest version of Anim8or I get "out of bounds memory" on my laptop running Windows10.  Most significant is mesh2path by NickE which I use quite a lot. Any body else had the problem?
« Last Edit: October 25, 2015, 09:03:08 am by kreator »
« Reply #456 on: October 25, 2015, 11:08:46 am »
Steve: I really like the new look with build 1194!
erm... i've tried running 1194, and the colours are all the same old light grey - how are you guys getting the dark/orange thing?
« Reply #457 on: October 25, 2015, 11:44:42 am »
Heres mine now , just cleared the registry and re-installed 1194 version
« Reply #458 on: October 25, 2015, 12:05:06 pm »
Theys be dark matters...Such devilment! must not be for the likes of us mortal folk.
we could end up losing our souls.
« Reply #459 on: October 25, 2015, 12:23:27 pm »
You only need to clear out the anim8or registry keys,
w10 apps/show all/windows system click run then type regedit
find HKEY current user click on that
find software click that
scroll down to Silicon Valley Software Highlight it then right click find delete Then click
exit regedit
and re-install Anim8or 1194 for a new look!
If you have any of the Directories allocated you will need to point them back again with configure in Anim8or
« Last Edit: October 25, 2015, 12:25:37 pm by kreator »
« Reply #460 on: October 25, 2015, 12:31:34 pm »
@ Kreator ...mesh2path doesnt work in last two anim8or releases win7 haven't tried others but works with 0.98 official release.
cheers for registry info.
« Reply #461 on: October 25, 2015, 12:33:43 pm »
Drewi: Mesh2path: Have now got it working on Windows 10!.build 1194.. The Tank treads were made with it!
« Last Edit: October 25, 2015, 12:34:18 pm by kreator »
« Reply #462 on: October 25, 2015, 02:06:56 pm »
kreator: can you send me the script that's crashing?
Everyone: Rats, looks like I messed up. The new color scheme wasn't supposed to appear until Halloween, but for installs on new computers it sneaks in  :-[ .  For everyone else you'll just have to wait.
(If you're impatient you can always go to the Silicon Valley Software registry directory described by kreator and set GUI.ColorScheme to 1.)
« Last Edit: October 25, 2015, 02:07:48 pm by Steve »
slex
  • 3D-TV
« Reply #463 on: October 25, 2015, 03:00:44 pm »
--Try to manually increase ''Undo buffer'' to about 100MB(default is only 1MB) in /file/configure/Undo buffer//.
Update//I finished test video made with dev.build 1194- rendering time was about hour. here's the link: youtube.com/watch?v=8qw0bYWg7qE[/youtube]]https://www.
   :) (btw. video is short, you can loop it by double right click and select repeat)[/color]
« Last Edit: October 26, 2015, 03:23:05 am by slex »
« Reply #464 on: October 25, 2015, 03:10:29 pm »
Slex:Yeah, I sussed that out after I re-installed 1194 and amended the config then everything was hunky dory again!
Steve: Not having any problems now, reset my config undo buffer back to 1oo meg and all is well again with a nice GUI in grey and Yellow cool.  Now You just need to get all the animation side sorted, IE: copy and paste Objects in scene mode instead of having to manually import them with Build every time!
« Last Edit: October 25, 2015, 03:15:48 pm by kreator »
