Author Topic: Figure Mode not showing object properly  (Read 5892 times)
fcabalo
« on: April 07, 2015, 02:12:57 pm »
When I'm done doing the object I needed for my project, I proceed to figure mode.
When I add that object to that bone, it doesn't display as what I expected.
It should be the transparent one but it show only the silhouette.
Re: Figure Mode not showing object properly
« Reply #1 on: April 07, 2015, 02:51:19 pm »
Does this happen with all objects or just this individual one? What version of Anim8or and Windows are you running, and what's your graphics card? Go to About->System Info and About->OpenGL and attach snapshots of those two to your post.
Update your graphics card drivers, and you can give the development release a try and cycle through different rendering methods using Ctrl+B. If it still doesn't work properly, zip up the project and send it to Steve along with your system specs and he may find a bug that's causing the problem (if it's an Intel graphics chipset, however, you're probably out of luck).
« Last Edit: April 07, 2015, 02:54:03 pm by Raxx »
fcabalo
« Reply #2 on: April 08, 2015, 12:48:46 pm »
I've fixed it already. I just messed up the view, but when I reset it to default it return back to normal.
By the way, thanks for the concern and suggestion Raxx.
