Author Topic: Adding objects  (Read 10269 times)
earp
Adding objects
« on: January 02, 2017, 08:32:25 pm »
How do add an object with the mtl, 's on the object?
AlecJames
Re: Adding objects
« Reply #1 on: January 03, 2017, 06:55:21 am »
Your question needs a bit more explanation.
If you are new to anim8or did you see the tutorials here http://www.anim8or.com/learn/tutorials/index.html
Check out "A simple walk" for a quick intro to lots of functions....
Re: Adding objects
« Reply #2 on: January 03, 2017, 02:11:05 pm »
I think earp is referring to the material file associated with the .obj file format. V0.98 doesn't read these files. However the current development builds do. Try this one:
build 1264 dated December 28, 2016.
earp
Re: Adding objects
« Reply #3 on: January 03, 2017, 09:37:16 pm »
The textures download as separate files. Do I have to apply them myself?
Re: Adding objects
« Reply #4 on: January 03, 2017, 11:53:29 pm »
You may have to. First try putting them in the same directory as the .obj file. But sometime the path name doesn't match, so just load them into the Anim8or project and then you can save an .an8 file and it will find them the next time.
earp
Re: Adding objects
« Reply #5 on: January 10, 2017, 07:21:17 pm »
Thanks everyone
