Author Topic: Can I change the default orientation?  (Read 7698 times)
AlecJames
« on: February 23, 2017, 03:25:54 pm »
If I have an object 'A' in object editor and I rotate it to -90, 0, 0 it is now oriented so it looks the same as object 'B' whose orientation is 0,0,0,
Can I change the default orientation of A so it now has an orientation of 0,0,0?
I tried cut and paste back the object, I tried to rotate the 'object /axis'.
Re: Can I change the default orientation?
« Reply #1 on: February 23, 2017, 03:57:47 pm »
You can do this if it's a Mesh or subdivision object in a round about way:
1) Rotate it -90, 0, 0.
2) Add a new, simple mesh, such as a dodecahedron, but add it so it's not touching the original mesh.
3) Select both meshes and apply the Build->JoinSolids command. This will reorient the object to 0, 0, 0 and adjust the points accordingly do it's still in the same place.
4) In the point editor drag-select all of the points in the dodecahedron and delete them.
You might also want to move the object's axis back to it's center in Object/Axis mode (hot key O)
« Last Edit: February 23, 2017, 04:00:13 pm by Steve »
selden
    • Modelling for Celestia
« Reply #2 on: February 23, 2017, 04:09:15 pm »
Steve,
My experience has been that there's no need to actually add another object: simply select the object which needs to be reoriented and select Join Solids. It seems to work fine even though there's only 1 object to be "joined".
Is there some reason this can't / shouldn't work?
Selden
« Reply #3 on: February 23, 2017, 05:16:09 pm »
Thanks, seldon. I didn't think of trying that!
AlecJames
« Reply #4 on: February 23, 2017, 05:41:05 pm »
I have 5 meshes as a group.  If I just join solids with the group selected it does not work. If I add a mesh, select the mesh and the group, then join solids, it sets the orientation to 0,0,0 (as I want) but I don't think it joins the mesh and the group - I can simply select and delete the mesh in edit mode.
I can reset the orientation with this procedure, thanks.
I'm using 1263.
