Author Topic: File Input add to ASL in Build 1321  (Read 49664 times)
« on: March 15, 2018, 07:34:47 pm »
Build build 1321 dated March 15, 2018 supports text file input in ASL Object Command scripts.
The ASL spec has been updated to show the new features. I've attached some sample files as well with a bit of explaination.
file_read_obj.a8s - imports .obj data files.
file_read_tokenize.a8s - lists the contents of a file as tokens.
Here's a link to the part of the spec that describes how to use the text scanner.
Anim8or can prompt the user for the out file name and location with the #file Directive in an Object Command or an Untyped Command script.
« Last Edit: May 26, 2018, 04:49:05 pm by Steve »
Claude
Re: File Input add to ASL in Build 1321
« Reply #1 on: March 15, 2018, 10:19:32 pm »
The ASL spec adress is wrong.
http://file///C:/Users/Steve/docs/RSG/Anim8or/website/scripts/spec/index.html
Have you updated the web site?
« Reply #2 on: March 15, 2018, 11:07:56 pm »
Oops! That's where it is on my computer :) Try this one: http://www.anim8or.com/scripts/spec/index.html
Claude
« Reply #3 on: March 15, 2018, 11:42:38 pm »
I realized that ,but I couldn't bypass your firewall.:)
nemyax
« Reply #4 on: March 16, 2018, 07:59:01 am »
Will there be a binary scanner some day? And what about output?
« Reply #5 on: May 31, 2018, 12:55:27 pm »
Awesome! I'm looking at creating an svg/eps import plugin using this new feature. Has spline creation via ASL been implemented yet?
