Author Topic: Extrusion negative amount  (Read 23420 times)
FWL
« on: March 22, 2020, 05:39:02 pm »
Hello Steve,
I don't know if it is a bug (if not then it would be a feature request  :)). When extruding a face with a negative amount (inwards) I don't get visual feedback of the amount of extrusion (besides the numerical indication in the lower status bar). The selected face stays on its original position until you let go of the mouse. Then it snaps to the new location. This makes it difficult to be exact with the depth of your negative extrusion. When extruding outward it does show the amount in realtime.
FWL
Re: Extrusion negative amount
« Reply #1 on: March 22, 2020, 05:49:06 pm »
By the way I found out that in subdivision modelling with working divisions set to 0 it works and you'll get realtime feedback. Only in mesh edting the issue occurs
« Reply #2 on: March 24, 2020, 05:28:26 pm »
OK thanks for the suggestion. In the mean time you can see a negative extrustion in wireframe mode.
