Author Topic: Hello, forum.  (Read 24305 times)
mrbeaver.07
Hello, forum.
« on: June 05, 2021, 10:40:23 pm »
I have a question: When I open file with my character (Mr Beaver) there is an error. It reads: If you want to... Can't open texture file: (Cancel to stop warnings) How to avoid this annoying thing?  ???
Re: Hello, forum.
« Reply #1 on: June 06, 2021, 04:47:20 am »
 I think it could be a case for 'house keeping'.
 When you go 'File - configure', thats where you set up where anim8or will look for things like textures etc.
 If anim8or can't open a texture, it probably means it's not where it's expected to be.
 Rectify by placing the required texture(s) into the designated folder, (designate a folder if you havn't already), or if the texture is no longer being used, then delete the reference in 'object materials.'
Edit. I think that Anim8or searches the folder which the anim8or file is in, as well as the pre-designated, (configured), folder.
« Last Edit: June 06, 2021, 04:52:38 am by johnar »
mrbeaver.07
Re: Hello, forum.
« Reply #2 on: June 06, 2021, 06:29:43 am »
Thanks, John! I finally find the source of problem! It is somewhat unused cube map texture that was used for deleted object. I don't remember for what it was used. It doesn't matter, thanks for reply! :)
