Pages: 1 [2]
Author Topic: Which looks the best?  (Read 50738 times)
RnDr FOX
  • Just Relax
Re: Which looks the best?
« Reply #15 on: June 01, 2008, 04:46:12 pm »
OK, OK I now you all want to know the secret but before I tell you I need to give you a background on why I am doing this. Also this is really good if you have a slow computer like me so if you have a good computer this won't help you as much but those who have a slow one I hope this helps you out a bunch.
BACKGROUND:
When I was working on my Saloon I noticed that it would take an extremely long time to load. The reason why is that I had about 7 textures (Got them from CG textures) that were 1.3 megabytes big and bumpmaps that were about the same which would equal to about 18.2 megabytes. It would take about 25 minutes to load my Saloon which was a pain. So then I was on a quest to figure out how to compress the textures but still make them look good and I finally found out.
WARNING:
You may find the secret disappointing as I have mentioned before so please don't get mad at me if you already knew this or it was a waste of your time and ect. With that said here is the secret.
THE SECRET:
As you may have noticed that most of you had chosen the 2nd one or the third one which made me really happy. What I do is load the texture in Gimp and I change the quality to about 80% to 70% from the original 100%. As you can tell it barely change the image so here are the numbers.
  • 1st one - 100% quality
  • 2nd one - 80% quality
  • 3rd one - 70% quality
Now you may think ok what is the point of changing the quality when I want the best of the best.
My answer is you can still have a good texture by lowering the quality while at the same time lowering the file size which also lowering the loading time.
All the textures are the same its just that I changed the quality on each one.
Here are some more numbers
  • 1st one - 1.33 megabytes
  • 2nd one - 970 kilobytes
  • 3rd one - 730 kilobytes
Sorry for the long post and I hope you all learned something new ;D
« Reply #16 on: June 01, 2008, 07:10:31 pm »
Fox. you don't have a slow computer, you are just feeding it more than it needs for the same or even a better result.
My chair is textured with a 186 Kb image (http://www.anim8or.com/smf/index.php?topic=759.0)
Bigger is not always better :)
Dosser
« Reply #17 on: June 01, 2008, 10:35:27 pm »
Fox, I must say, my idea for the secret was very different. No offense to you, but I also think I am correct in my secret :P
Look at the filenames of the images you posted: they are all exactly the same image
http://i306.photobucket.com/albums/nn258/RnDrFOX/Test1.jpg
heh, did you link us to the wrong pictures? :P
« Last Edit: June 01, 2008, 10:37:28 pm by Dosser »
devilGames
« Reply #18 on: June 01, 2008, 10:57:50 pm »
Actually Dosser, it's all one picture, i just had a look (at the code). There is only one picture, which means that RnDr Fox has made a picture, with a grey background, and stuck the 3 pictures on it
« Reply #19 on: June 01, 2008, 11:01:08 pm »
Dosser, RnDr FOX only posted one image containing three different renders. (sorry, posted at the same time as devilGames)
As for textures, it only makes sense.  Afterall, if you compare the size you're rendering at, to the size of the texture, you shouldn't see any real comparable difference.  Textures from CG textures are gigantic.  If you don't size them down (at least in anim8or) it will take a very long time to load.  Sometimes I like the preserve the textures quality when creating a texture, such as for my mascot, though I kept that as a high quality photoshop file, then I save it as a much smaller .jpg.
Dosser
« Reply #20 on: June 01, 2008, 11:16:47 pm »
ahh, that makes much more sense :D
It is amazing though, in 3D modelling. A relatively poor model, combined with a relatively poor texture can look remarkably good.
RnDr FOX
  • Just Relax
« Reply #21 on: June 02, 2008, 12:00:17 am »
Yea what silver said is correct I made three cubes and put the three different textures on them, it is all one render. Don't worry I am not trying to trick you all or anything, I just discovered something that I thought was incredible and I wanted to share it.
Silver- the pics are still ok quality, as you said there is not much notable difference and all Gimp does (as far as I can see) is make the texture a little bit lighter as you decrease the quality
NEW INFO:
It turns out that the bumpmaps where actually 13+ megabytes (dump bitmap) so I converted them to .jpg and lowered the quality a little bit (if you thought it was hard to tell the difference before wait till you see the compressed bumpmaps)
Also before I compressed the textures and bumpmaps it took anim8or about 25 minutes to load the file on my computer now it only takes 6 minutes ;D
spicy
« Reply #22 on: June 02, 2008, 08:47:19 am »
Gimp? Well that explains it then, I would never notice the level of quality
Bobert
« Reply #23 on: June 05, 2008, 01:54:04 pm »
They all look just about the same to me although 1 and 2 seem a little warped.
saderguy
« Reply #24 on: June 09, 2008, 04:48:26 pm »
I can see where most people are coming from with this: The third one is bolder. I guess whether you should use it depends on the project.  :)
Pages: 1 [2]
