My base
hihosilver:
Here's a tutorial on using shadows in Anim8or that I wrote and is hosted on the main site. Hope it helps.
headwax:
http://animanon.com/Upload/user_uploads/ensoniq55edf/freightterminalwmmtest.wmv
Check this out by the indomitable ensoniqu
and http://au.&eurl=http://animanon.com/Forum/index.php?topic=246.0
just so you know who yoy are taking advice from ( I mean who is giving you the advice)
General Clivis:
im trying white the schaduws but evrey time i put a spot on it it becomes very dark.
how can i solve this?
thanks for the responses im learning allot
ENSONIQ5:
I'm sorry, I don't understand what you mean. Could you post some renders?
hihosilver:
When you use a spotlight, that is currently the only light in the scene, meaning everything else should be completely black. To lighten it up you simply add more lights of different types. For example you could add a local light, or, if you wanted to light up the scene uniformly, I would suggest and infinite light, as it would act like a sun in a way. You can then turn down the intensity of this light so it only lights up the scene as much as you need.
Navigation
[0] Message Index
[*] Previous page
Go to full version
