Your opinion about optimal computer system for Anim8or
<< < (2/2)
ronaldefarmer:
What would be required to have Anim8or use the entire processor during rendering?  Would that be a major modification or a minor one?
Raxx:
That would depend on how familiar Steve is with the multithreading architecture, and how adaptable his code is already. OpenCL would require a bit of homework on Steve's end, likely.
These days, renderers are combining both CPU and GPU for faster rendering. Those that don't are falling behind. It'd be nice to have native support for a free renderer, like LuxRender, or the Renderman spec, or at least full Scene export plugin capability via ASL so that a third party can write a plugin for them.
Though, before that, I'd rather he overhaul the skeletal animation system and make it more intuitive....
cooldude234:
yea I'd agree with you on that. I mean it's kinda contradictory that anim8ors worst feature is animation :\
ronaldefarmer:
I do wish that Anim8or could render my scenes faster. It is also true that I would like to see a few new features added. For the record though, Anim8or is the one program that I use most often outside of work, including software that I have paid a lot of money for. I like Anim8or primarily because it is easy to use while at the same time being very capable just as it is. I don't want to seem like I am complaining about the speed issue; I just want to get the best possible performance.
ENSONIQ5:
I agree with Raxx's assessment, the biggest single factor in Anim8or rendering speed is CPU speed.  These days I generally render in Carrara which is able to run a rendering 'tile' for each thread (Carrara renders images in a series of top-left to bottom-right tiles rather than a single full-width scanning line).  With multi-threading on my quaddy there's 8 simultaneous rendering tiles working on a single image, with CPU usage at 100%.  In addition to this, Carrara can manage network rendering, so any other machines on your network can be pressed into service.  When I link my quaddy laptop into a render there's 16 tiles of rendering goodness running simultaneously!
This isn't an ad for Carrara, there's many things I don't like about it and many that I love about Anim8or (and many things I continue to use Anim8or for), however in my opinion the rendering speed of Anim8or is the biggest restriction to using it for actual animating.  Admittedly I've not tried the method of running multiple instances of Anim8or to render separate blocks of frames simultaneously, this would certainly be worthwhile however even with this workaround the rendering speed is really not very good, especially running the ART renderer with a decent load of ART attributes.
We've all got our Anim8or wishlists and they're all probably a bit different, render speed is at the top of mine.
Navigation
[0] Message Index
[*] Previous page
Go to full version
