General Category > Anim8or v1.0 Discussion Forum
Anim8or v1.01.1318 doesn't select all surfaces
bioconcave:
--- Quote from: selden on February 04, 2018, 03:40:05 pm ---For some reason I hadn't realized that Anim8or could import .STL format.
--- End quote ---
Probably because it's a relatively new feature (since 1.0 was released I think).
Steve:
selden I'm finally getting time to fix all these issues. The problem is that Anim8or doesn't go into Groups to select faces. This should be easy to fix.
#101-023 - Ctrl-A Doesn't Select Faces in Groups
selden:
Steve, thanks!
Steve:
This problem should be fixed in the latest build: build 1329. Let me know if it solves your problem.
selden:
Steve,
This new version does select all of the faces.
Thanks!
Navigation
[0] Message Index
[*] Previous page
Go to full version
